Trailing Movement in PRemiers CS3 HDV final files
tibobjerome
Whether it's Cineform avi or any other media-encoded file format, the movement of the subjects leave a strobe-like trail. The trail is there even when the subject doesn't move as long as there's camera movement.
I capture through HDLink, with all the recommended settings on the Cineform forum for the HV20 camera. I edit on Adobe Premiere CS3 (Aspect HD). The only thing I didn't choose specifically is the FRAME FORMAT which I left on "Automatic" rather than "progressive". I figure Cineform will be right detecting if the format is interlaced on progressive with that option. Other than that, I check REMOVE 3-2 PULL DOWN (HV20) and DE-INTERLACE 1080i.
When I add slower/faster time remapping speeds, the strobe trail in movement is even worse. That's the biggest headache I have with Cineform to date. Everything else seems to work fine. I do have XHA1 cameras which I'm going to test later, but right now, I'm testing the HV20. Here's an illustration of what I'm talking about:
http://www.vimeo.com/2002505
PLEASE HELP and feel free to ADVISE! I'm a newbie by ALL counts.
I got an answer from Cineform. The issue is not with premiere. It's user error (mine) resulting from the way I imported the clips from Cineform HDlink. I added deinterlace when I already asked to remove 3-2 pulldown.
So if anyone comes accross that issue, the best way is to check the conversion/codec specs and make sure everything is in line with the type of HD file you're importing.
