Trackmarker follow on/off ?
phorus
Hey,
This is littlebit hard for me to explain because im not english but i can try
When i press play the line starts to run forward in tracks (to the right side).
When im in very zoomed in position and press play, it always shifts me to different position in the track after the line marker reaches the rightside edge. Then i have to zoom out, find the previous spot again, zoom in and do it again. So when im in very zoomed in position, it reaches the right edge of screen very fast (2-4sec) and it skips to different location in track very fast and its hard to adjust the cuts and key points while running the video.
Does somebody know is there way to turn this follow option off ?
Thank you very much if somebody could help!
No, but you can place a marker on the start position by pressing M.
You can also create a loop region around your start point loop the playback so it doesn't go far.
In Vegas 12, Expanded Edit Mode may help.
