Nathyn
Low Budget Ninja
Okay. This is the total workflow I'm considering, so tell me if you think this is hot or not. I may not be able to get the new FCP but I believe FCE is well within my reach. Now this is what I'm thinking:
1. Since the new FCP/FCE software won't edit ACVHD on PowerPCs you can get a copy of Toast (I talked about this already) and convert the files, Toast is actually pretty quick at doing this too.
2. FCE doesn't do 24p so go ahead and keep the files @ 30p when you convert the files via (The 24p video will be in a 30p stream on some of the Canons consumer models).
3. Edit the project as a 30p project in the open Timeline and output it.
4. Convert to 24p via Apple Compressor.
5. Once you're all said and done and you've got your final version, take your file and save it to a small harddrive and have it dubbed to HD master. Your distributor will want this if you have distribution.
So, what do you think about this workflow. I haven't tried it yet but it makes sense. Is there anything I'm overlooking?
-Nate
-Nate
