Toshiba's Gigashot A100 Full HD camcorder (consumer camcorder)
Nik Manning
http://gizmodo.com/gadgets/toshiba/...all-full-hd-camcorder-from-toshiba-303277.php
Anybody check out the Toshiba's Gigashot A100 Full HD camcorder.
10 x zoom lens
Real-V engine reduces picture noise.
Records in 1920×1080i and 1440×1080i resolution at 60fps in MPEG-4 AVC/H.264 format.
Recording modes of XQ, HQ, or SP
A100 has 12 hours' capacity of full HD video, 23 hours of standard
35 mm Fujinon lens with 45 mm diameter
3-inch LCD screen (320 x 240 res)
SDHC-compatible SD card slot
Audio recording at16bit/48kHz at 384 kbps bit rate
Measures 78.1 × 135.4 × 79.0 mm
A100F weighs 495 grams
A40F weights 485 grams
Battery life approx 75 mins
Lithium ion battery
Comes with AC adapter, remote control, USB cable, AV cable and D terminal cable.
Hopefully it is sweet and cheap!
Yes but who wants a 1080i interlace camcorder? Progressive scan is the only way to go. However Toshiba is also introducing some high speed 720p models that can capture video at 60 frames per second. Toshiba offers these models at a discount which is not a bad deal considering that 720p offers better picture quality than 1080i.
Everyone isn't making movies with there camcorder so they don't need 1080p24. TV shows can be shot interlaced especially reality shows.
Even for reality shows news and sports progressive is always better than interlace because with progressive you can shoot at 60 frames per second and not just 24.
