STORYTELLER32
I'm editing a friend's short film and he's sent me all his footage already captured on an external hard drive. He shot with the anamorphic adapter for the DVX.
Each time I drag a clip to the timeline I get the red bar indicating the clip needs to be rendered before I view. This happens each and every time I make a slight alteration to the clip.
Is there a setting I can adjust somewhere to get FCP to not require rendering under these circumstances? I seem to recall when I worked on my own short, that I was able to simply drag clips into the timeline and edit at will without constant red bars showing up.
Help is appreciated-
Timeline Sequence settings are as follow:
720x480 NTSC DV 3:2
Pixel aspect ratio: NTSC - CCIR 601/DV
Anamorphic unchecked
Field Dominanace: lower (even)
Editing timebase: 29.97
Anamorphic is checked on all his clips in the browser bins. When they're unchecked the footage looks squeezed in the viewer window.
720x480 NTSC DV 3:2
