macs Well-known member Aug 23, 2005 #1 Is there a way to avoid time code breaks when you shoot with the dvx100a?? I cant do batch capture cause i always get time code breaks... thanks! max
S Scottdvx100 Veteran Aug 23, 2005 #2 Hit Rec Check button after powering down or rewinding/reviewing.
Sirius_Doggy Veteran Aug 23, 2005 #3 You may want to also check and make sure you are not set to Free Run on the TC. You should have it set to Rec Run if you want continuous TC. Do that and what Scott mentioned and you should have no TC breaks.
