tilt shift efffect
bgerber21
I have a rrm2 and want to use a nikon 35mm pc lens to effect the tilt shift look ie:minaturized image dof. Will this lens achieve this or will i need a tilt adaptor ,if so where can a find this adaptor?
You''l need the tilt as that's what'll give the effect. I don't think that the 35mm nikon has tilt, only shift. The 85mm nikon pc is the only one that I know of that has both tilt and manual iris control. You could also look at the hartblei tilt adapters for medium format lenses. Or get an older hartblei 80mm super-rotator.
