vidled
DVXuser Sponsor
Okay so these lights have been popping up from time to time. Misleadingly called HMI - they are in fact HID not HMI.
I picked up a ballast & a 140W bulb for $125.00 from here.
PDF here
Just quickly checked it out, and it's pretty decent; puts out quite a bit of light, and flicker is manageable. Has a 5 min warm-up and cool-down period.
Combined with an alu-reflector and/or softbox, this might be a lightweight way to travel with some ~700W of "daylight", and using only 140W. Might try and run it off an inverter next....
Yep, ran perfectly fine off a 300W (I think) inverter, and it was a cheap modified sine one, not a pure sine one.
I'll probably put one of these into a box with a batterypack and an inverter. Should be sweet.
CRI isn't awfully high, maybe upper 80s?
Would also be very neat, I reckon, as a replacement of a household bulb if super brightness is required (just check max ratings and temps of fixture to avoid fires, etc.).
PDF here
