alignment1
Hey all-
After being inspired about a year ago from Edweirdo's 35mm adapter, I finally have mine built.
Through extensive research, I finally ended up going the 'Jetsetmodels' route, (thanks Daniel) with one of his vibrating GG holder's.
However- I am still having image issues
I seem to be getting quite a bit of vignetting and extreme blurring around the
edges of the frame.
Here's the setup:
DVX100B camera
72mm Cine HD achromat lens (india)
72-55 step ring
55mm circluclar polarizer filter (no glass)
EOS extension tube set (sections 3, 3, 2)
VH-57X Ver. 2.0 (w/ rheostat)
Canon Ee-A focusing screen
Multi-Coated UV filter (dust cap)
Canon FD to EOS mount (with glass)
Canon FD 50mm 1.4f lens
I've tried different variations of the extension tubes, doesn't seem to change
much, (still vignette/blurry edges).
The FD lens is wide open, (but I also tried stopping down 1 or 2 stops. The more I stop down- the darker the image, and more vignetting is happening.
The camera settings: It's in MF, autostabilizer is 'OFF' iris is wide open to
about 2.4 or so.
Shutter speeds 1/24, 1/48, 1/60
I feel like the vignetting is happening at the focusing screen. When I look at
the lens through the focusing screen(off of the camera) it looks like there
might be a bit of vignetting. Any suggestions?
I've seen footy on here using similar setup with great results.
I know I can somewhat correct the problem in post, but I'd much rather fix the problem at the camera.
Pics/Vids to come( Iknow it's easier to 'see' than 'read'
:dankk2:
Zack
edges of the frame.
Here's the setup:
DVX100B camera
72-55 step ring
about 2.4 or so.
:dankk2:
Zack
