KenV
Ok, so I've noticed that alot of films on this forum could benefit from better ADR.
But, not all of us have the budget to go into a studio and do a full blown ADR session. So, how do we fix this?
First of all, you recognize that the dialogue in your film does not have the best sounding attributes (i.e. has lots of reverb/wind noise/general noise).
The remedy.
Rule Numero Uno:
A good actor will deliver lines great even if they are not being filmed. Remember that. . .
A. Re-record the dailog from a moderate distance on the same set/room/ambience. Act like you were 2 people away from the actors in the scene and record the conversation from that point of view. Do a couple takes.
B. If you did a shot outside, and wind/ambience is your problem, record from a medium distance shot from where the actors are inside a controlled environment, much like if your where shooting a close up/medium shot of the actor from an inside location. Then record some outside ambience, or completely sound design it, and mix it in with the rest of dialogue.
C. If your not sure, then just record another take in a medium sized room from a conversational distance, and add "room tone" to it later.
All this depends upon your willingness to re-record and edit the audio without video. But like I said before, your actor should nail it with your supervision.
And if your ADR sounds great but doesn't match up to the video, well this is the reason why ADR editors are hired in bigger productions.
And if your ADR matches up, but doesn't sound great, well this why ADR editors are hired in bigger productions.
This is the best advice I can give.
Noise reduction plugin's can only go so far, . . .
and awsome original recordings make for awsome sound.
KenV
The remedy.
Rule Numero Uno:
KenV
