You can normally buy third party coolers or you could go down the water cooling route.I bought the Asus P6X58D-E motherboard and a P7 920.
I just realized the PCI express slots are too close to the PCI slots. The new graphic cards are so thick, you can't use the PCI slot next to it and therefore you can't add audio cards, eSATA cards, or anything. That is a major problem. The only solution is to remove the heat reduction piece from the graphic card, be it a fan or a metal add on. How are others dealing with this?
