SirTed
Hi All!
I've read the forums a number of times, and while my subject is similar to many before me, I wanted to be a little more specific in my questioning. I apologise for the long question - but better you have all the details up-front and avoid having to drag it out of me!
I need your help to assemble a lighting kit for basic corporate video/documentary stuff - which demands lots of basic interviews and the like (I realise that there is lots of stuff on this here already - I HAVE read through it). I also have to travel, which means I need to be able to take a basic kit on the road with me (and through LOTS of airports). When you live in Australia, to get to anywhere means a LOT of travel, and you have to travel a long, looong way!
Most answers to "the lighting kit question" suggest building up a kit over a period of time. They also say hiring is a great way to get experience. I have already gained some slight degree of experience (having gone through film school and a few other basic technical courses) with lighting. So still an iggerant novice, but starting to learn! So far I have been hiring a Lowell-Rifa 500W for interviews and using all the practicals I can find in (typically) office environs!
I want to start investing more in lighting - so I'm wanting to buy a kit now, as
a) you need a versatile toolbox to create a variety of looks/images;
b) the hire companies don't want you to travel with their gear - and certainly don't make it easy for you; and
c) I'm often left to the mercies of whatever the hire companies have in stock (I often have to shoot at the last minute)
I also need to buy most of the gear in one shot (as its not my money that I'm throwing around!). My budget is AU$5,000 (which is around US$3,500).
So I figure I'm looking at a basic 3-4 light kit. The Lowell Kits look good and versatile for the money, but seemed flimsy when I played with anything other than the Rifa, (this seems to be the consensus on these forums). So I want something better quality and more reliable than Lowell (these things are travelling after all), but with similar versatility.
So these are the things I'm considering:
For a key light:
a Lowell Rifa light (500watt); or
a Kino Flo Diva 400; or
a Dedo DLH200S with Softbox
(why are these not talked about on the forums? are they new? crappy? under-powered? too expensive? Dedo have a good reputation over here... but for hard lensed lights - can they not make soft lights?)
This is the light most interesting to me - the marketing for this is that it has "twice the output of a fresnel in a soft box with a more even light (no hot spot)"
- if that's true, is a 400watt softbox enough of a key?
Since it can go either tungsten or daylight - is the daylight function any use? I must admit I have very little experience shooting outdoors - presumably if filming outdoors, it would be used as a fill light, but would it make much more of a difference than just bouncing the sun? The sunlight in Oz is INCREDIBLY bright. The entire country is burnt! Which makes it very difficult for a one or (if I'm lucky a) two-man crew to hang a sheet out to screen/diffuse the thermonuclear death we call the sun); The other benefit to having this daylight/tungsten switchable light is that i'd find it easier to use indoors with lots of sunlight through windows... What are your guys thoughts?
For the fill light, I figured I would either go for
a Kino flo 200
or
bouncing/reflecting a hard light, like a Dedolight or an Arri 300watt (we don't get Mole's in Australia), depending on budget.
then for a back/hair light, using another Dedolight, and maybe getting a cheap Tota light for boosting the ambient light.
Most responses to these type of questions tend to recommend getting big lights - 1000watt lights etc which has not seemed necessary for my needs - my first interview experience was with a Redhead kit - and even with some spun diffusion over the front, it still managed to cook my talent!!! (you can actually see the poor guy sweating and turn red - it was a ...learning experience!).
Why do people recommend bigger light kits? Is it simply to ensure you can also light bigger areas? Is there something I am missing? For Documentary type stuff with untrained talent, I want lights to be as unobtrusive as possible - and I certainly want to avoid cooking anybody!
A tota light with a speed ring and soft box seems very popular but is that not over-powering? I've been stuck filming in some very small offices - which means the subjects being very close to the lights!
I'll probably be stretching it to get this kit on the money I've got - (with case, grip gear, and decent stands thrown in) should I be thinking of something cheaper?
The other question I had was how do you bag these lights when travelling? I can't take shotbags with me inter-state - even if I could afford the excess baggage charges. What do you resourceful gaffers/DPs use to keep lights from getting knocked over? I've heard of a shot bag that you can fill with sand or water (!!!!) but the very idea of water near electricals sends my blood cold.
I hope you can give me some advice on this!
Thanks!
yours,
ted.
For a key light:
a Kino flo 200
or
Thanks!
yours,
ted.
