I have been really impressed with some of the footage I've seen from various 35mm adapters, including Brevis and Redrock. But to make the adapter usable, you need to flip the image.
Every method I have come across just seems to be quite a big hassle. It eliminates the potential for recording very simply, i.e. just point and shoot, which is sometimes very useful to be able to do. It seems that you need to either connect a laptop, use a paperclip stuffed into your hvx lcd hinge (hoping you don't damage anything!), use a separate bulky flipped monitor, i.e. the marshall... (with all the time it takes to set up...) or use a substandard 35mm flip adapter with loads of light loss.
What is the best solution for free and easy shooting? It would be so much easier if panasonic allowed you to flip the screen with a menu option.
This is really impacting my decision to get any adapter at all, which is a big shame since I love the images that I have seen. I consider the workarounds described above (because that's basically what they are) very counter-productive in terms of creativity and spontaneity.
What is the simplest solution? Perhaps there is a top quality adapter that shows a right-way-up image with very little light loss out there somewhere? If so I would love to hear about it... I would pay a lot for something like that. Will panasonic maybe introduce a screen flipping option as a menu item? Many other cameras, even way cheaper than the hvx200, allow you to do this.
Look forward to hearing others' thoughts on this.
