The great "next shotgun" debate
Greg Smith
My first short shotgun microphone was a Sennheiser ME80 -- used that for everything back in the '80s and I thought, for the price, it had a very sweet sound. Those were analog 3/4" tape days for me, though, and standards have changed. When I started seriously upgrading my equipment about five years ago, I got an ME66 since I thought it was going to be a close equivalent -- but of course, as we all know, it isn't. It works well mounted on the camera as a general ambience mic, but on voices it is pretty thin sounding and disappointing.
So help me select my next shotgun. Applications range from general background on the camera, to on a boom for interviews, to occasionally as a handheld interviewer mic when I'm shooting in a noisy industrial environment. (Therefore, sensitivity to handling noise is one issue for me that might not be quite as important to everyone else.) Although it sounds shallow to say it, looking professional and being respected by my peers when I show up for a shoot does matter as well.
While I won't say price is no object, I'm at least able to consider the entire range of models listed below. However, I don't want to spend money that won't actually be heard in the quality of the end product, so if you think it's not worth investing in a Schoeps, for example, please feel free to tell me so.
In order of increasing price (current new prices from B&H, rounded off to nearest $50), I'm thinking about:
Rode NTG-3, $700
Sennheiser MKH416, $1000
Sanken CS-3E, $1450
Sennheiser MKH8060 with MZF8000 filter module, $1700
Schoeps CMIT5U, $2200
I'll deal with wind protection, shock mounts and so forth separately -- just give me opinions on the mics themselves. I kinda think I know where I'm heading with this, but would like to hear the opinions of the experienced folks here who may have used more of these than I have.
Thanks in advance!
- Greg
If I was buying now, I would go for the new MKH 8060 or the SuperCMIT (the SuperCMIT is considerably more).
The SuperCMIT is an AES42 digital mic.
The MKH 8060 is an RF condenser (analogue) - but as the capsule can be removed from the XLR module you can insert the MZF 8000 filter module (or anything else Sennheiser may do in the future) - also - it is future-proofed in that you can easily turn it into an AES42 digital mic. by swapping the XLR module for the MZD 8000 digital module.
Although I don't have an 8060 at the moment, I do have pairs of both the 8020 and 8040 and also the MZD 8000 - so I know the sound.
After these I would consider the CMIT 5U, it's a good mic.
I would not get an MKH 416 nowadays, it's a design f the 1970s and is low output and noisy when compared to modern mics like the 8060. The NTG-3 is really, as I see it, Røde's attempt to copy the 416. Yes, they did a good job at an affordable price, but if you can afford something better I would certainly go for it.
An MKH 8060 or a Schoeps will probably last you the rest of your life (yes, even if you are in your 20s :Drogar-Happy(DBG): ).
Covering all the applications you list really calls for two mics and selecting just one of your candidates leaves some gaps, especially in regard to booming indoors for interviews. Of those you list, the Sanken CS3 is probably the most general purpose mic in that it doesn't exhibit as many of the bad traits in reflective environments as do the other conventional 'guns.
I (and many others I know) have gone for the CMIT in a similar situation like you and never regretted it for a second.
The new MKH 8060 is supposed to be fine indoors and much better than the 416.
While no one mic will be the best choice for every situation,
if you only have 1 of these to choose from I would go for the CS3e.
The only real downfall of the mic is it has a higher noise floor so in a quiet location and with very quiet speaker you're going to hear a bit more hiss
than say the CMIT (by the way the super cmit is total overkill dont even consider it for your needs)
The cs3e has too many positives to outweigh the smaller negatives, and would be an excellent "only" mic choice.
My opinion. (I own or owned most of the mics on your list and use them in many situations on a regular basis)
Postives- Great indoors AND outdoors. Ridiculously good reach compared to other shotguns. Good off axis rejection.
Negs- The sound is very good but not quite as pleasing as a Schoeps CMIT or cmc6/mk41. Higher noise floor. Not as good in humid environments
as a sennheiser (ive never had an issue but worth mentioning).
I agree with almost everything you said, except not getting a 416 nowadays. An 8060 is still a lot more money, you definitely can't get used ones (if you could they would be the same price minus tax). A great sounding mic (416) at $700.00 used vs a great sounding mic (8060) at $1700, I'd go with the 416. Now if you already have a 416 for years and want to upgrade or just want another mic, then the 8060 is a great choice.
I'm going to be getting the 8060 soon and I am very excited about it. I just need to find someone that has it so I can hear it for myself in action.
I still think it's a great idea to get a hold of the 8060 and give a listen yourself. As the 8050 and 8040 sound great, they have had issues on the boom which the MKH40 and MKH50 do not have. Also worth considering that the filter module with the low cut and pad aren't quite up to snuff. As a fan of Sennheiser and owner of an MKH50, I hope they come up with a better filter module to make the 8000 series better for boom work.
I believe the on-board low cut on the MKH50 is 4db at 50Hz compared to the MZF 8000 filter module which is -3dB @ 160Hz (Switchable) and -3dB @ 16Hz (Fixed), not ideal IMHO.
Still looking forward to some shoot-outs with the 8060 and other short shotguns. From the samples I've heard thus far, sounded a bit harsh (more sibilance) in the high end but not putting much into it until some proper uncompressed files are posted.
count me in that category. i don't want to regurgitate schoeps' marketing blurbs, but compare it, side by side, with other shotguns and the off-axis sound is very natural sounding. sometimes a 416 sounds like a life-saver, but usually it's overkill and there's a price to pay for that laser beam-like pick-up pattern. weight not being the least of it.
for a camera mic the cmit just seems like a no-brainer to me. the on-board filters, good pick-up pattern, weight... the only down-side is the price. as an interview mic, it's beautiful. the only other mic i considered strictly on the basis of how sweet it sounded for interviews was the kmr81. but side by side the neumann just sounds too rich and syrupy for a mic i wanted to do every job. i know the cmit is expensive, but it does everything i want it to do, very well, and i've used it for nearly 5 years now.
i haven't heard an 8060, though. i'm curious about it now. sanken though, i have an almost visceral reaction against their mics when i've got the cans on all day. you couldn't give me one.
Yes I'm waiting to hear it for myself as I have read really great reviews but only heard poor samples. Also Some really poor reviews that I think were based on samples and not personal experience still got me questioning whether or not I should pick one up. I would love to hear a shootout against the CMIT 5 U indoors. These are two great shotguns that are supposed to sound good anywhere.
John Willett said:
Talk to Sennheiser Canada - I'm sure they could arrange a loan one for you through your local dealer (or maybe even direct).
I had already gone to my local dealer and they didn't even have the mic in their system, but I will try this route when I get back home and see if they can hook me up.
Though it'll be a while, it'll allow time for me to hear goetzpd's shootout.
Looking at UK prices, the 8060 seems to be pretty much the same as the 416 without the digital option- less than I expected, considering how much the other 8000 series mics are
I've read so many reviews both good and bad about the mic. They even had sent out a bundle of mics that weren't manufactured right I also read. I haven't had time to check myself yet waiting for some good shootouts and user reviews
