_joe
Ok, before throwing a "24fps looks better than _____" argument, know that I take this topic from a recent article I read in the creative COW mag that I wanted to share with y'all. I don't understand much of it, but I wanted to see if any others have read it and what their thoughts were.
If I understand correctly, John Galt (Panavision VP of Advanced Digital Imaging) says that most if not all people are confusing pixels for resolution, so while we argue about 720 or 1080, 2k or 4k images, he argues that pixels make a difference, but only up to a point. He says this about a test done with IMAX tecs, which most people think as 4K:
he then brings it to the argument that 24 is going to be moving to 48. Mostly because 24fps was designed for sound:
He then talks about how high speed cameras (1000fps) look much sharper than cameras that have 4 times the resolution.
I mean, it's in development, but do you think that this is the future? Or because resolution will hit a ceiling with pixels, and possibly with frame rate as well, people will say "it's sharp enough" to hold to the 24 standard?
A Number of years ago some IMAX technicians [...] showed this film they made that began with 2 rows of 2 squares: black white, white black, as if you had 4 pixels on the screen.
Then they started to double and double and double the squares. Before they got to 4k the screen was gray. You know what that means? There was no longer any difference between black and white, which is what allows you to see sharpness. It's the contrast that we see, not the actual information [...] so if you had true 4k resolution in your local theater, everyone would have to be sitting in the first 6 rows. Otherwise they wouldn't see any extra detail. Their eyes wouldn't let them see it.
Back when they were creating optical soundtracks, they discovered that they couldn't get intelligble sound on the film, which typically ran at 16 fps. They eventually setlled on 24 frames per second with a 2-bladed shutter: 48 exposures per second.
Now if you take a still picture of somebody walking in front of you at 48th of second [sic], you know that they're going to be blurred- motion blur. But if we were to record 48 frames per second with a 2-bladed shutter, then the intergration time would be only 96th of a second, and each of the images would be sharper
