the best ND filters for dvx
scotman
hey guys, whats the best ND filter I can get for my new DVX and where. i bought one from BH, its a haze, but it doesnt fit, and i dont know how good it is. Thanks
The in camera ND is fine, but it is such coarse steps that often you will overshoot the actual value you need. I would strongly recommend getting a nice 3 filter set (.3, .6 & .9) either screw on if you are not using a mattebox or 4"x4" or 4"x 6" if you are. One other suggestion, consider getting the next size up and use a step down ring at the camera to help avoid vignetting when shooting wide. In the case of the DVX, use 82mm filters and an 82 to 72 step down ring.
thanks for the adive khmuse, but im a little new owning a pro camcorder and could use a little more explanation. thanks dude
