Text "writing" effect in Vegas?
mehnkle
Is there a way to get a "writing" text effect using Vegas? I have searched high and low and haven't found anything. Thanks for your help!
You mean like handwriting?
Use a handwriting font. Then keyframe a bezier mask to reveal it along the path you choose.
Do a search in the help menu ... Vegas' help menu is amazing.
Otherwise, in the pan/crop window, select MASK, and then make the outline you want by placing the anchors down. Then, just key frame the movement of your anchor points, and it will move the mask with the key frames ... I know I'm not explaining it well enough for you to do much with, but to simply give you a QUICK idea & encourage you to check out examples in the HELP section.
