eugenes
I plan on having a dvd-10 disc duplicated with an NTSC version of my video on one side and a PAL version on the other side. I am all set with the NTSC materials, but need some advice regarding the PAL version.
I had planned on sending it to a colleague in Africa, where he would test it on a PAL DVD/TV combo. Unfortunately, I will not have time to send it overseas before we need it mass replicated.
So, my question is . . .
1. Is there a way to test a PAL authored DVD without using PAL native equipment?
2. Using the workflow listed below, would it be inadvisable to mass replicate the disc without testing it on native PAL equipment.
3. Would it be best to consider burning just an NTSC disc since most PAL devices play NTSC fine, anyway.
Any other suggestions?
Here is my workflow, in case you need to know it.
1. The piece has been edited at 23.98. I will be using Graehme Natress's conversion filter to convert the movie into a 25 fps timeline.
2. Next, I will export it from fcp to compressor, and use the advanced format setting to set it to PAL.
3. Next, it will be imported into DVD Studio Pro and burnt using PAL settings.
Thanks in advance.
Thanks in advance.
