tascam dr100 + sd mixpre = how to set up?
in a few weeks i'm on an audio only gig for a local radio station.
they are providing a tascam dr100 and at803 lavs. http://www.bhphotovideo.com/c/product/68272-REG/Audio_Technica_AT803_AT803B_Mini_Clip_On.html
i did a quickie test the other day and was stunned by the low levels i was getting and the noisy pre-amps on the dr100.
i used the at803 with phantom power and the mid gain engaged and still had to record near 9 to get decent levels.
i have a mixpre from my own audio kit.
i was going to use their at803 lav powered via phantom from the mixpre which should offer a cleaner, louder signal.
would i then go xlr out of the mix pre into the tascam dr100?
or line out from mixpre and line in on the tascan dr100?
if the later line out/line in set-up,
what type of cable would i be using?
thanks in advance for any info you care to share.
be well
rob
smalltalk productions
i
be well
rob
i
