Hi All, this is my first post, but I've found a solution to an audio for video problem that I researched here on DVXUser. A while back I read a lot of threads of how the combo of the DR-40 and NTG-2 didn't give enough gain to get good audio from a boom 3 feet out while avoiding hiss from the Tascam input volume needing to be turned all the way up. I read these because that is the combo I happen to have, and not a lot of budget to replace gear. I did tests and the noise was there with the boom 3' from actor. I first tried getting an inexpensive Pre amp: the ART USB Dual Pre. The amount of phantom power was the same as the DR-40, so I didn't get any more gain. But running the mic with the AA battery in it, XLR to the Pre (with the phantom power turned off), 1/4" out and into the DR-40 using the "Line" input. While I got no more gain, the signal was cleaner. It took the hiss out at the low end, and added a warm tone to the audio. Since then I have found a better solution. There is a somewhat rare in-line pre amp out there called the FetHead from the English company Triton Audio. It adds 20db of gain to the signal! I connect the pre to the mic (XLR) [with the battery in the mic to provide phantom power for the mic], then XLR cable into the DR_40 with Phantom power on, to provide phantom power for the Pre. The sound was big! The FetHead added the gain as advertised. I could turn the recording level down on the Tascam to 20-30% instead of 90%+. Since I had the Dual Pre anyway, I ran it through it also and this gave me a additional way of adjusting the gain. Mic with battery - to FetHead- XLR to Dual Pre (w/ phantom turned on) - 1/4" to DR-40 using "Line" input. This gave me the same levels and quality, but I could adjust the gain with the dial on the input for the Dual Pre as well as on the recorder. This gave me a little more control. I now get big audio without the noise. I tested the mic on a boom 4' away from the dialog. It was clean and big! There are few people who carry the FetHead. The one place I found was ZenAudio in North Carolina. Nice people, really prompt and helpful. It's $99.
