OSCURO
https://www.ebay.com/itm/196160273566
Everything is in perfect working order: all ins/outs, switches, buttons, menu settings, cables, and lavalier work flawlessly without any issues whatsoever.
NOTE: This is the UK/International version of the DR-10L that features a locking 3.5mm analog output for tethering to a wireless transmitter. Very useful for monitoring, camera hop, and further redundancy. Original owner, purchased brand new and handled with care. The included custom-made 3.5mm to TA5F cable for Lectrosonics adds to its versatility.
Package includes:
• Tascam DR-10CS compact audio recorder
• Tascam TM 10LB lavalier with locking 3.5mm connector
• Locking 3.5mm to 3.5mm output cable (for Sennheiser G2/G3/G4 wireless transmitters)
• High-quality custom-made locking 3.5mm to TA5 female output cable (for LECTROSONICS wireless transmitters)
• Sandisk Ultra 32gb microSD card (not pictured, installed)
About
"TASCAM’s DR-10C-series recorders connect to your lavaliere microphone to create a compact recording system that fits on a belt pack. This version is the DR-10CS for Sennheiser mics and features a 3.5mm jack input that has Sennheiser microphone compatibility.
The DR-10CS recorder has both inputs and outputs, so it can either be used stand-alone or with a wireless transmitter. When used with a transmitter, the DR-10CS acts as a backup to protect against wireless dropouts during recording.
The lightweight DR-10C runs for hours on a single AAA battery. It records to standard microSD media. Recording features include auto-gain and a low-cut filter for simple setup. Its dual recording feature records a safety track of your audio at a lower level, so in case of distortion you have a non-clipped backup. "
Features
• Micro Linear PCM Recorder for Wireless Beltpacks
• 48kHz/24-bit mono digital recording
• Uses standard microSD/microSDHC card media (up to 32GB) included
• Dual Recording feature captures a safety track in case of distortion
• Hold function prevents accidentally switching off the recorder (All keys cannot operate during recording)
• Limiter and low-cut filter on input
• Auto gain control
• Records BWF file timestamped with time of day clock
• Time Track increment function writes new track after a preset amount of time.(There is on/off setting, but the time is 15 minutes fixed when turn it on)
Package includes:
About
Features
• Auto gain control
