The most important factor is to try to continue with one tapestock once you start with it. Jumping around, especially between manufacturers can cause you some issues as each manufacturer generally uses different types of lubrication on their tapestock. Some use wet lube, others dry lube. Jumping around from tape to tape can cause your heads to start sticking with the mixtures of lubrication.
In addition, tape recycling isn't good either. If you have to, fine. Otherwise, we have found that customers generally get longer head life if they only use their tape once than if they recycle.
It's great if you recycle paper plastic and glass though!
Best regards,
Andrew Hoffman
Senior Operations Manager
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
301-790-0103
Fax: 301-790-0173 andrewh@spec-comm.com www.spec-comm.com
Remember "Taping over Black?" Are we still supposed to do that? (You know, pu the lens cover on, hit record for the whole tape, then record your footage over that black now on the tape?)
yikes, unless you know something i dont, I would say no way. It's digital, 1's and 0's. A chase scene or just black, data's data, and every time you record to that tape your increasing the risk for dropouts.
That was a huge myth about Mini-DV, "stripe" you tape! Problem is, when a Mini-DV camera records, it just records, it doesn't track TC already on the tape, it writes new code from scratch.
Don't waste your time, it does nothing but wear down your cam faster.
