REHov520
Hi,
When your exporting out of Final Cut, what would be essentially the same as printing to tape and then re-captuing it to your hard drive? Is there some export compression rate that would produce the exact same result as this? If you just export to default quicktime the quality is less than tape, and if you export uncompressed the file is too huge. Is there a way that would be identical to printing to tape and then recapturing?
