T-Power
safarijoe
Is there any difference between t powered mikes and phantom powered mikes? Imean is there a major performance difference?
Zordon Film said:
also, you need some sort of a power supply adaptor to run the T-power mics.
http://www.trewaudio.com/catalog/subcat131.htm
usially if you work with normal eng or made for film mixer you dont need any adaptor - the majority of the field mixers supply t(ab) power , wendt(all models) ,sd 302 ,442, mm1 , psc ,cooper(104,108,208),sanosax,audio development (all models)),shure(31,2,3) ,soundcraft lm,sqn(all models) and few others
for all the rest and 99% of video cameras you need that one
ExileOnTheMainStreet said:
why ,you still can get new 416 t or even mkh 60 t if you like ( spesial order)
:thumbsup: Okay so basically the only real difference is that A) the T powered mikes are old (unless you special order some new ones) and B) you might have to buy the adapter if you're not using a decent mixer. Otherwise there is no difference except they might be cheaper used. :laugh:
