Sync Problems, HVX and GH-1 footage
djkarn105
So I recently completed shooting a short film on the GH - 1. We didn't have an audio recorder available so we ran mics to an HVX we had on hand. I've logged the footage in Final Cut, importing only the audio from the HVX footage, but when I'm trying to merge the clips to sync the audio and visual, the audio track comes up short. If, however, I lay the audio into my 24fps timeline, it comes out the correct length and syncs with the visuals.
My guess is that, when you merge the clip it matches the timecode frame by frame (this makes sense mathematically because the audio is about 1/3rd the length of the visual.) So the question is, how do I get the timecode to match? I've tried modify>timecode on the audio clip and setting the framerate to 60 and matching the slate frame timecode but that didn't seem to make a difference.
So, what can I do? It's going to royally suck to have to sync each clip in the timeline and I edit.
so after piddling with this for a few hours. I have two solutions.
If I convert a clip from the gh-1 from 60 to 23.976, import that clip and merge it with the audio it syncs fine.
I can also, drop both clips into the timeline, link them and then drag them back to the browser and I have a properly synced merged clip.
Neither solution is ideal but I'll take what I can get.
