Pretty much yes, ask the sound recorder to record at 48khz then make sure the project's sound track is set to 48khz as well. There will be no problems syncing them.
But some times the sound track can fall out of sync. Simplest solution is to place a cut every 5 minutes on the audio track. Shift each clip along by what ever amount of time needed usually a few frames will do. This is not ideal but unless you can sync TC by sending TC to the recorder and use a TC slate this method will do.
Today I'm gonna shoot a concert with 2 DVX100s and the audio will be recorded separately.
To avoid the problems which may occur later, I wanted to know which settings I should ask the audio man to change, is it just the sampling rate or is there anything else?
