donjohannes
Hi Everyone,
I'm looking into doing some video sessions for a larger project in which I would like to achieve a super white background, somewhat similar to the popular apple vs. pc clips ( http://www.youtube.com/watch?v=lgzbhEc6VVo ) though full body shots are not a must.
Now, as I understand, there are different options:
1) use a green screen and then key it out. Disadvantage: you need a large studio (which I don't have) to get the right distance between screen and talent + work hard to get a good key.
2) so maybe use a white screen: roll of seamless paper, I guess, or vinyl. Disadvantage: you still need a large studio to get the right distance between screen and talent. Great tutorial (photography: http://www.zarias.com/?p=71)
3) Use a Lastolite HiLite. Question? anyone ever tried putting a permanent light source inside and use this for video? Naturally it would have to be something that doesn't get too hot, like those energy saving light bulbs, whatever their abbreviation is... Here is the Lastolite for those that don't know it: http://www.bhphotovideo.com/c/produ...e_LL_LB8867_HiLite_Chromakey_Background_.html
Advantage: You could place the talent right before the screen shrinking the space needed in the studio. It would be your back light. Technically I can imagine that the setup could even be used as a green screen substitute if you fill it with a colored light. Then it would beat the Reflecmedia solution in some respects, because you no longer have to worry about the reflection on things like glasses. There might be some color spill, so...ok...
4) go a little DIY on this one, i.e. by using fabric that is used in softboxes and creating a screen (eg. 10 by 10 feet) that is then lit from the back. Maybe get something like this: http://www.photoflex.com/Photoflex_Products/LitePanel_Fabric_Translucent_77_x77_/index.html . Same advantage as the Lastolite but maybe that would solve the heat problem. Do you think such a large area could be lit evenly from the back?
Has anyone experimented with any of this and can share experiences or has an advice?
Thanks,
Johannes
Thanks,
Johannes
