Ashton Lamont
Since you have not purchased a Zoom H4n as yet I suggest your life may be easier if instead you purchase two Zoom H1's at less than the price of one H4n. The H1 has a 3.5mm plugin power socket so it will take any lav (though Sennheiser proprietary screw jack ones can be loose). This should be much easier to handle than two wired lavs on different people going into one recorder. If your chosen lav is wired such that it records on one channel simply duplicate in post for left and right by whatever means your NLE allows. That should be fine for your voice content.
The H4n has its drawbacks but poor user experience is I suspect down to individual unit failures not general shortcomings. Having said that mine does take a few seconds to boot up, I think it about 12 secs with an 8gb card. It uses batteries quickly with phantom power on but you'll still get well over an hour per set and probably far longer. I don't find the preamps unacceptably noisy. It also has a 3.5mm socket which you can use for an unpowered lav if you enable plugin power in the menus. You can plug lavs into the two XLR sockets but you need special adapters which can be expensive and increase the bulk. It will lose your recording if the batteries run out.
For cheap robust lavs that perform decently try Giant Squid. You can also specify how long you want your wire with them so you don''t end up with a 30ft wire going to a Zoom H1 in the talent's pocket :- )
Just run the H1's all the time and use your onboard 7D audio just for syncing only. If you can stetch to it Pluraleyes will do that for you in seconds.
I'm not sure, I guess that the two speakers will be at different distances from the cam - interviewer and interviewee? A shotgun mic is probably a non-starter in that case because its so directional and would I assume not be manned all the time, not to mention its also going to be several feet from the audio source.
Pete
Pete
