Super 16mm and FCP (interlacing problem)
eppdidit
If anyone has edited Super 16mm on FCP, please lend me some help! I have FCP 5.0.4., Dual 1.8, G5 and I'm trying to cut together footage shot at 24P from a Super 16mm camera. The footage was transfered down to an external hard drive and converted into Quicktime files.
The footage is interlacing and I can't seem to find the corect mode to edit in. I've tried a 23.98, 29.97, & 30 sequence mode, but none work. I refuse to use the de-interlacing filter because it makes the footage look like CRAP! There must be another solution.
I need help quick, we need this video cut together yesterday! Any help is much appreciated!
thanks,
epp
www.eppicfilms.com
The easiest wa to get the Timeline correct for editing, is to look at a clip in the bin and match that to your sequence settings. The biggest to check for are Framerate, Compressor, Frame Size, and Anamoprhic.
