is your case going to just be for a DVX or a DVX&ACCESSORIES?
a pelican 1450 would be great for a DVX, batteries, filters but it would be completely full. you may want to go with a bigger case (1550) if you wanted to add a microphone. so list out everything you want in to put in your case. just a reminder going to big is never a bad thing
[quote author=greeches link=board=Links;num=1100738154;start=0#6 date=11/17/04 at 21:33:53]anyone try the Dosko Sport Extra? 65 is pretty sweet.[/quote]
I've got one that I use for my prompter. It's really basically the same thing as the Pelican, just less expensive. Same sturdy bulletproof type of construction, same waterproof o-ring seal, same pick 'n' pluck foam, and about the same size as the 1550. I'd recommend it.
My DVX was bought as a kit & the recommended case was Pelican 1600.
I have been able to fit Camera, 4 Batteries, Charger, 10 Tapes, Remote, Various Leads & my little Panasonic NV-DS55 which uses the same Batteries etc. It is large, but I would kick myself if I couldn't fit all my bits & pieces in. Still a little space left which I am sure to fill.
