Did they change how you access "No Fill" when using the Pen Tool? It was convenient to have that button down by the background/foreground switch... now I don't know how to make my pen a no-fill and I can't work in photoshop without it...
Pen tool has shape mode and path mode. In shape mode you can choose a style of stroke with no fill, fill with no stroke, pattern or whatever. In path mode you can make a path and then as a work path or saved path turn it into a selection which you can stroke or fill however you want.
When you choose the pen tool, some more parameters show up at the top left of the screen. There are like three little boxes next to each other with the pen tool in the middle of them. I forget which is the one you want but click on one and make a path with some angles in it. You should be able to figure it out quickly since there are only like 2 or 3 options.
