Jon Forsyth
Hi,
I thought the hard part was done -- shoot it, edit it, tweak it -- now I just had to create the DVD. That was 4 days ago.....
My previous project (also shot on a DVX100B), which was my first big one with CS5, ran into quality problems: The encoding by AME looked terrible. After much trial and error, I learned about encoding using lagarith and HC Encoder, and that seemed to work (finally), so I thought it would be easier this time. But, that hasn't been the case. The main problem is interlace combing in the finished product (or really lousy quality if I get rid of the interlacing, even with lagarith).
Some details:
Footage: Mostly SD shot on Pan DVX100B. My last project was at 24P, and I thought maybe (probably mistakenly) that my quality problems were related to going from 24 to 30 for the NTSC DVD, so this time, I thought I shot at 30. However, thanks to user error (mine), about half of the footage was at 24P.
Editing: In Premiere Pro CS5 (v5.0.3, Win 7 64 bit), everything looked fine on the timeline and during playback, in the Source Monitor and Program Monitor. I created the sequences by dragging the primary file to the New>Sequence icon, so the sequences were created with the same specs as the file.
* Sequence 1
** Settings: DV NTSC, 29.997 fps, Lower Field First
** Clip, Modify Clip/Interpret Footage: Use Frame Rate from File: 29.97 ; use Field Order from File: Lower Field First
* Sequence A
** Sequence Setting: DV 24p, 23.976 fps, No Fields (progressive scan)
** Clip, Modify Clip/Interpret Footage: Use Frame Rate from File: 23.976; Remove 24p DV Pulldown checked, Use Field Order from File: Lower Field First (not sure about this one, but under Properties, it also says Frame Rate: 29.97 (24p), so I assume that's related to the "24p but not really" deal with the DVX)
When it came time to export, I first tried an entire sequence, but after seeing how bad the results were, I tried small segments, eventually just exporting a 5-second clip and trying every combination I could think of to get good results. I've tried it on multiple sections of the clip, without any great success.
I've tried every export combination I could think of, with both the interlaced footage and the progressive footage. It either has terrible interlace combing (if I use Interlace/LFF settings), or it comes out splotchy and jerky (if I use progressive). The only one that works reasonably well is the Microsoft AVI/NTSC DV preset -- however, that has be further transcoded, so it doesn't do me any good. All of the others, including AVI with lagarith codec, mpeg2 DVD, etc., result in terrible interlacing combing (or blotchiness).
I don't want this to go on to long, so I'll stop with the detail, but I am totally stumped. Making the DVD used to be the relatively easy part, after the hard work was done, but CS5 doesn't like this footage, for some reason.
Can anyone help (or is there more detail I can provide)?
Thanks,
Jon
Some details:
* Sequence 1
* Sequence A
Thanks,
Jon
