Structure Free and Structure LE gone?
Gohanto
Maybe this is old news, but I've been using Structure Free in PT for a while to pitch sounds on my keyboard. I hadn't re-downloaded it upgrading to PT 9, but was just looking at upgrading to Structure LE anyway when I noticed that NEITHER version seem to be available anymore, only the full version of Structure.
Anyone know when that happened?
Only slightly OT. I went through a couple of soft samplers (that I payed for) that eventually went away. You can usually find a way to translate the presets but you lose all the time you spent learning the application. For simple pitch changes I tend to use Soundminer but for all the sampler related stuff I got a used E4 XT Ultra fully loaded on eBay for less than I payed for the soft samplers. Nobody want's the hardware anymore but it doesn't care what version of OS or software your running and never needs updating to be compatible. With the Ultras you can swap out the generally small SCSI internal drive for a nice bid ATA drive.
One of the better decisions I have made.
For pitch shifting I'm a big fan of Pitch n' Time Pro. You can literally draw the pitch over the audio waveform. It also has nice time compression and expansion. Best pitch changing plug-in I've ever used, next to the crazy stuff that Sound Toys has, that is.
I agree, a fantastic plugin... But $800+ The E4 has very smooth pitch changing as does Soundminer. Both though slow down the sound to change the pitch. Pitch n' Time is in it's own league, I haven't seen anything that does what it does. I just haven't needed it enough to justify the cost.
