Hello everybody!
My mini DV Cam is PAL interlaced. Ok, no problems with capture, editing, etc. But after rendering out in any video format /.avi,.mpg,.wmv/ as progressive video file, the rendered video looks so much worse than original interlaced footage - strobed, strobed, strobed even in little slow camera moving. The result is exactly the same even if I render source interlaced footage out in dv avi pal PROGRESSIVE! Anytime I render out in interlaced format, the rendered video looks ok. So, is there a method or setting which can make an excellent result from interlaced footage to progressive??? The bad result is both on the monitor and TV.
My settings are:
Template: PAL DV (720x576; 25,000 fps).
Field Order: Lower field first. If I set None/progressive scan/ - bad results!
Motion Blut Type: Gaussian Frame Rate: 25,000 (PAL).
Deinterlaced Method: Interpolate fields. If I set Blend fields or None - bad results!
Smart resample is ON. Reduce interlace flicker - better if is OFF.
Would somebody describes step-by-step all the thing I have to do in Vegas, so that to get a nice PROGRESSIVE video at last? I tried many tutorials and examples, but everytime one and the same. Thanks in advance!!!
My settings are:
