Stream my videos to my dlna compliant bluray player
VideoMaker
I am a long time Vegas user currently on 9c. I recently bought an LG BD390 bluray player which is dlna compliant. I will be upgrading to 802.11n but am currently connected to the player via 802.11g. I have been able to stream 720p30 Sony AVC renders at a bit rate up to 2Mbps.
My rudimentary tests suggest I could get a better quality stream if I render to DivX, perhaps up to 4 or 5 Mbps. I'm not sure why renders at a given bit rate could stream differently with different codecs, but that seems to be the case. Correct me if this is not a correct assumption.
Also, in case it matters, I am streaming from TVersity on my Windows Home Server.
But here's the rub... the LGBD390 loves DivX, but it needs the audio stream encoded as AAC. I'm trying to find a way to encode DivX WITH AAC audio within Vegas, but haven't hit on a solution yet. Anyone here have any suggestions? Is their an AAC codec available that will work with DivX?
I have DivX 7, but it requires that I output a neutral format from Vegas and then it can convert it to DivX and AAC. I want to be able to do this all within Vegas if possible.
BTW, I'm shooting AVCHD with a Panasonic HMC150.
