Stream Error FCP7
longshanks
Hi,
I've been logging and transferring some footage that has worked seamlessly. But I'm having trouble transcoding two clips that stop part way through the transcode and give me a 'Stream Error'. Wouldn't you know it, but these two clips happen to be the most important part of the edit that I need. I've tried Voltaic HD and that worked ok for 10 seconds (demo mode) but when I purchased the full version is gives me a 'failed' conversion as well.
I did notice however, that with the Voltaic HD demo it would have a 'glitch' or pixelated mosaic similar to a botched DV tape. I should note that playback in the Log and Transfer window is flawless except for the same mosaic-like glitch that happens at the exact same time in the clip.
So do I have corrupted MTS files or is this AVCHD folder structure needing repair? I haven't messed with the folder structure at all because I know what a mess that can be.
Please help!
