Strange things Happen When Rendering
Woodson
In Vegas When I render in Widescreen settings. My short doesn't turn out to be widescreen. When I render in 24P NTSC dvd arichtect it turns out to be good and in widescreen. All these in mpge 2 file. I shot the short in 24P advance, with a 16:9 adapter, Hmmm. I don't get it. But I'll stick to what looks good, even though I do not know what is going on with the setting and why. At least it's in 23.976.
Re: Strange things Happen When Rendering
Save as type: Mpeg 2
Template: DVD architect 24p NTSC video stream ( not widescreen cause when I choose that option the video looks smaller and doesn't fill a wide screen.)
Then we go to custom:
Under Project...
Video redering quality : good.. (should this be switched to best?)
then video...
Video type - dvd, ( maybe this should be mpeg2 here?)
frame rate- 23.976 + 2-3 pulldown
aspect ration- 4:3
b- frames - 2
maybe the widescreen that i'm seeing isn't true widescreen?
I also notice that when I go to click on my clips in vegas and go to properties under media in the field order - says None(progressive scan) should stay like that right?
but in the Pixel aspect ratio I have 0.9091 (NTSC DV) should this be 1.2121 (NTSC DV widescreen) even though all my setting are at 23,976 and widescreen, except there. And if yes.. do I have to go right clicking each clip from start to end.
and in alpha channel - none
You have to change the pixel aspect ratio on the clips to be NTSC DV Widescreen (1.2). You do that in the Vegas project and then for all the clips. Then when you render it'll all be treated as widescreen and the DVD will be flagged to be widescreen.
[quote author=Barry_Green link=board=Vegas;num=1100576423;start=0#4 date=11/15/04 at 23:32:03]You have to change the pixel aspect ratio on the clips to be NTSC DV Widescreen (1.2). You do that in the Vegas project and then for all the clips. Then when you render it'll all be treated as widescreen and the DVD will be flagged to be widescreen.[/quote]
thank you Barry... the thing though it was set up to 1.2 widescreen on project properties but not on the clips... weird.. do not get that.
I'm so happy to hear that, now I know what the mess was...
and also now i can change the aspect ration- to 16:9 correct?
in rendering.
hmm .. also in video type do I choose DVD or Mpeg 2
frame rate 23.976 or 23.976+ 2-3 pulldown ?
video rendering quality good or best?
template: dvd architect NTSC 24p Widescreen? or doesnt matter?
You have to change the aspect ratio in the clips manually. The camera sets the widescreen flag if you use squeeze mode, but it doesn't set the flag when you shoot anamorphic, so you have to set it manually.
Once you set those flags, then set EVERYTHING to 16:9 and you'll have a flawless workflow.
For rendering I use the MainConcept 24P MPEG for DVD Architect preset. If you've re-sized any video (zoomed in on pictures, etc) then use BEST, otherwise use GOOD.
This 16:9 flag.. is that only when rendering under the aspect ration when rendering right. There's no setting for 16:9 to switch in Vegas. Just when I render right? the only thing in Vegas is to put it in widescreen 1.2 on the clips right? but no switches to 16:9.
When I use the dvd architect 24 NTSC widescreen in the template then I go to custom... under video I get 16:9 which is what I want... but under the frame rate I get 23.976 + 2-3 pulldown .. why is that? because when I switch that to just 23.976 and go back I do not have dvd architect 24 NTSC widescreen anymore, the template switches to untitled.
