strange lines on edge of frame problem
tomk358
Strange problem here- I had a project that worked fine in PPro2, now in CS3, it exhibits the following problem:
This is a project in 'desktop' mode, 24P, 350x400px, for export to FLV.
I have a jpeg image on the timeline. It's white with some color in the photo. When I apply a dissolve transition to this clip, as soon as it starts to fade from full white, a bright line shows on the right side of the screen.
If I set the project to 'maxuim bit depth', it goes away, but when I then render out an FLV, the line shows up again. The only way I could solve it was to keyframe the opacity of the clip to imitate the dissolve- which fixed it, but it's a bit problem.
Any ideas?
I tried making the jpeg into a targa at 24bit or 32bit, but it didn't help.
-Tom
Did you ever find a resolution to this, I have the same issue. I have a cineform 4k project with several stills in the timeline. I took all my photos to photoshop and set the image and canvas size to fit 4096x2048 pixels. When I place a pan, zoom rotate effect on the photo and animate it with a little movement I get those same lines you described. Some photos I have regenerating the PSD after I have placed the zoom on it worked, other it didn't. I'm going to keep searching but I'd like to know if anyone could expplain why this is happening.
