Hey all, I recently had to reinstall my OS on my G5 because the boot sequence randomly got corrupted after downloading a service update. (Re-installed with keeping all original files)
Here is my problem now:
I had an old FCP project with HD footage using HD compression and edited as such. After the reinstall of the OS which kept all original files, it seems to have done something to my FCP only pertaining to this compressor. When I load the project from scratch, here is the message I get:
"Codec not found. You may be using a compression type without the corresponding Hardware Card."
I brush through this by pressing OK about 5 times, and the project loads. When it loads, there is no timeline. I then try to open an original timeline and I get the same message, followed by a message saying "Out of Memory". Then finally I go into the settings of the timeline to see what the problem is and I get this message:
"Video compressor HDV 1080i60 was not found. Please check that the hardware is present and enabled for this compressor. Setting the video compressor to Animation."
After this I am able to go into the settings and indeed, I see no HD compressor at all.
I really am at a loss at what has happened, perhaps I should reinstall FCP? Is it possible to do so without losing all my projects and current scratches? Anyone have any ideas? Thanks very much in advance.
