Strange Audio Issue
tayproductions
I received a video of an interview. It has a music bed underneath the interview. When in stereo it plays fine. If I change it to mono and both channels are selected, the only audio I hear is the music bed (no audio from interview). When I turn off either mono 1 or mono 2, it plays fine. I can't figure out why selecting both mono 1 and mono 2 gives me just the music. Any suggestions on what's going on? Am I just missing something simple?
My guess would be that the audio from the microphone interview is 180° out of phase between the left and the right channels, which means when the audio waveform travels upwards in the left channel, it travels downwards on the right channel. That way, when you add them together, your microphone signal is perfectly cancelled out. The music seems to be in phase so it would only amplify when you add it together.
You already found the best solution, just throw away one or the other of the channels. Getting more complex and less likely to sound good, you could try to invert the phase of one of the signals and then add them together. Then your music *might* cancel out and you could be left with just the audio from the microphone by itself. It's probably more likely, though, that instead of cancelling out, the stereo music track would end up cancelling out components of the signal which are in both channels equally and then you'd be left with the instruments which are panned left or right.
This is actually a trick karaoke machines try to remove the vocals from a song, which are most often front and centre, and leave the panned instruments for you to sing along with, with varying success.
