I recently purchased a 1.2K HMI ballast on ebay. This one has a different connector to other ballasts I have used in the past and can´t find out what kind of light it´s for. Does anybody know if there are adapters to make it work with a standard LTM Head?
You would need the appropriate veam connectors for each end to start, and then need to know the pinouts for the ballast and the head. Looks like your ballast has a 12 pin connector and I'm willing to bet your lamp head has a 7 pin connector
Here's a schematic link that would probably work for your lamp head pin out http://galaxyrepairservice.com/whats_new.html
Thanks for the help guys! Found out it is compatible with a Pro Photo HMI I have so probably will keep it for that. I will also give GLR a call, perhaps convert it to the more standard 7 pin connector if it´s not too expensive.
