still images - what frame rate?
When working on a picture montage, there is the ability to easily edit in whatever frame rate we want, unless there is video incorporated. Then comes the question of what is the best frame rate to work with. Unless I am mistaken the decision is simpler than it seems. There are really only two options. interlaced or progressive or rather 30p or 60i to be more precise . Obviously these are handled relatively the same throughout the editing but which one gives a better look. with 60i you are able to achieve faster motion more smoothly, for quick transitions this seems to be ideal. 30P might give you issues with trying to create a high motion montage but you also get the progressive feel of motion while panning a picture from left to right ect. One downside I can see with 60i is if your pictures are overly sharp and show anti-aliasing. If this occurs and is not treated properly by adding a directional blur of some sort, than the areas that are stair stepping or experiencing this problem are much more apparent and begin to role (this happens a lot in peoples eyes from my experience) These days when a lot of people are caught up in 24p (myself included) we almost have are default timeline set to 24p but this is just something to think about before starting to edit an video. 24p isnt going to look any different than 30p with stills except give you less frames a second to work with. So unless you are editing a two hour long picture montage and would like to make it space saving for DVD or intend and doing a film-out of pictures consider other options.
I'm not sure about the space saving theory- I think Premiere distributes those 24 frames over 60 interlaced frames, so you're really working with 60i no matter what you do. But I'm not the expert.
The biggest for me regarding your project would be the consideration of stuttering motion in a 24p project. Since your framerate is lower, any fast movements of pictures won't be as smooth as a 30p or 60i project. 24p is mostly for mimicing the look of film, and if you're not using any video (or film) footage, the effect is lost for the most part. I'd go with 30p or 60i.
its very tue that the effect is lost when you are comparing 30p images to 24p images or if the image isnt moving than 60i images as well. You can save space by or rather gain quality by editing in 24p advanced. if you export using adobe media enocder and use the 23.976 frame rate and make sure to set your "n" frame to 12 instead of 15 you will be getting a higher bitrate dedicated to fewer amount of frames per second.
