Still image not scaling properly
filming
I made a freeze frame inside FCP but when I try and scaling it it does not scale in the center like a normal clip but it scales to the side. There is not filters of effects so why do it so that?
Switch on image + wireframe view in the canvas and you can drag it wherever you need. Also you might need to adjust the anchor point and distort tab in your clip's motion properties to get it all correct. For complex moves, I suggest switching to motion. Nice Flash btw. :love4:
Noah
I tried it and no solution. This is what I did.
I freeze frame and then scale it.
When make I freeze frame the picture is the same size as the clip I am freezing the picture from but the scale properties say 100% on the picture and 47% on the clip. They look the same size but the scale properties are not the same. When I try and scale the freeze frame from 100 to above it just scales to the left.
