Steadicam Zephyr, Nikon D600, Nikkor Lenses, GoPro Hero3 + More, Los Angeles, CA
arencher
http://alanrencher.com
The current equipment packages that I own are listed below. I will be adding more, so check back soon. I do not normally dry-hire my Steadicam, but I do rent out my other gear to productions. Please contact me for operating rates.
Steadicam Zephyr Package – $350/Day
  • A/B Battery Mount
  • Secondary A/B Battery Plate (12/24v)
  • Standard Vest
  • 7″ Marshall HD Monitor
  • Red One & Red Epic/Scarlet Power cables, 4-Pin Power Cable (+ additional and redundant power cables)
  • Camera Mounting Chassis (Sled)(23 lb capacity)
  • 2-Section Iso-Elastic Arm (36 lb lift capacity)
  • X-Y Vernier Stage
  • Drop-in Dovetail Camera Mount
  • 2x Lemo Power Connector on Stage
  • 2x BNC Connector on Stage (composite and HD)
  • 2-Section CF Post
  • Dual Rod Base
  • Docking Bracket
  • Low-Mode Bracket
  • Hard Case
  • 5x Anton/Bauer Dionic HC Batteries
  • 2x Anton/Bauer Twin Quick Charger
  • Filmtools Steadicam Jr. Magliner Cart Conversion w/ Backstage Accessories
  • American Grip 2-Stage Steadicam Stand w/ Casters
  • Steadistand Collapsable, 20″ C-Stand
Bartech Digital Wireless Follow Focus – $125/Day
  • Bartech Focus Device (BFD) Transmitter
  • Bartech Digital Receiver (BDR)
  • Loon M-One Digital Motor
  • Digital Motor Cable
  • BFD 3-Pin Lemo & P-Tap Power Cables
  • Rod Adapter Collets
  • Various pitch Lens gear Adapter Rings for M-One
  • Hard Case
Wireless HD Package – $125/Day
  • Paralinx Arrow Transmitter & Receiver (HDMI)
  • Decimator Design Decimator 2 (Converts HD/SD SDI to Composite & HDMI)
  • Blackmagic Mini Converter (HDMI to HD-SDI Converter)
  • Ikan 9″ Monitor w/ Anton/Bauer Gold Mount Plate (P-Tap and USB Power outputs)
  • BNC Cable + Various Power Cables
Camera Package – $200/Day
  • Nikon D600 Full Frame DSLR
  • Nikkor 28mm F/2.8 AI Lens
  • Nikkor 35mm F/1.4 AI-s Lens
  • Nikkor 50mm F/1.8 AI Lens
  • Nikkor 35-50mm F/2.8D AF Lens
  • Various Macro Adapters
  • Nikon WU-1b Wireless Mobile Adapter
  • Blackmagic Hyperdeck Shuttle 2 External Recorder (records to Apple ProRes, Avid DNxHD, & uncompressed QuickTime)
  • x2 128GB SSD Drives (w/ cases & reader)
  • Anton/Bauer Gold Mount
  • Shoulder Rig: 15mm LWS Rails, Shape Handlebars, Berkey Top-Handle, Portabrace Universal Shoulder-Pad
  • Noga 5″ Articulating Arm w/15mm rail adapter
  • Hard Case
GoPro Package – $50/Day
  • GoPro Hero3 Black Edition (4k, 2.5k, HD; up to 240 FPS; built-in WiFi; 12MP 30FPS Burst)
  • GoPro HD Hero2
  • GoPro Body Mounts, Head Mounts, & Helmet Mounts
  • Suction Mounts
  • LCD BacPac
  • Battery BacPac
  • WiFi BacPac
  • Hard Case
Micro Grip Car-Mounts w/ Triangulation Kit (holds up to 25 pounds) – $65/Day
  • Filmtools Mini Ball Leveling Head w/ 3/8-16 & 1/4-20 tie Down Slots
  • x8 Mathews Mini Grip Heads
  • x8 Mathews Micro Grip Heads
  • x2 Gutter Hooks
  • x2 Tie Down Straps
  • x4 1/4-20 Mounts
  • Hot-Shoe Mount
  • x4 3/8×4″ Aluminum Rod (tapped 1/4-20 w/ threaded rod)
  • x4 3/8×8″ Aluminum Rod (tapped 1/4-20 w/ threaded rod)
  • x4 3/8×12″ Stainless Steel Tube
  • x4 3/8×24″ Stainless Steel Tube
  • 1/4-20 to Baby Pin Adapter x2
  • x6 6″ Wood’s Powr-Grip Suction Mounts
  • 4.5″ Wood’s Powr-Grip Suction Mount
  • Mini Mathellini
  • Various Hardware
Lighting & Grip Equipment – $50/Day
  • Mole Richardson 1K Baby Solar-Spot
  • x4 Bardwell & McAlister 1K Baby-Keg Fresnel
  • x2 Bardwell & McAlister Rolling Baby Stand
  • Stingers
  • Grip Clips
  • 2″ Spring Clip w/ Baby Spud
  • Baby Scissor Clips
  • Sandbags
  • Assorted Gels and Diffusion
Weekly rates available. Please contact me to get a quote.
