SteadiCam wireless transmitter to monitor?
Hi everyone -
Kinda new to this, so bear with me.
Basically, I want the steadi-cam to be wire free but not have to walk next to him and watch the 7" monitor. Anything out there where I can sit in front of a monitor 25ft away and watch?
I have a transvideo titan system:
http://www.bhphotovideo.com/c/produ...ET_95TITANSET_Titan_Wireless_Transmitter.html
These types of equipment is usually suplied by the operator so you might look into hiring an op that supplies this.
Also another alternative:
http://www.kvconnection.com/ProductDetails.asp?ProductCode=T-CW-5HD
This is the next gen using 802.11G connection but lot more expensive.
Rentals are the best solution.
For monitors:
If you are using the Titan you dont have to go above a Panasonic 17" (my recomendation) as the signal is SD.
http://www.bhphotovideo.com/c/produ...T_LH1710W_BT_LH1710W_17_Widescreen_HD_SD.html
The Camwave can carry HD signals so I usually opt out for a 23" panasonic.
http://www.bhphotovideo.com/c/product/595914-REG/Panasonic_BT_LH2550_BT_LH2550_26_WIDE_HD_SD.html
Hope this helps.
I've seen the wevi wireless transmitter in action before and it's really sweet. Great picture quality.
