Hello everyone, so I have decided to venture into glidecam/Steadicams since cinematography is something I want to pursue. I purchased a Vest + Glidecam kit and I am having some issues. Camera is balanced very well with a 2.5-3 second drop time. I can spin the gimbal on the vest and the camera pretty much stays level with the horizon. My shots are great when it is just walking but running is where I am getting the issue with the vest.
There is major bumps in evey step and I am not sure if its footsteps or literally the spring arm jumping up and down. I can hear a noise from the system as I run, the springs are loaded for up to 5kg, I am using a c200 with a sigma 18-35mm and about 4 counter weights on each side. It did come with springs rated for 10kg. Could it be that the running motion causes the springs to compress more and cant handle the weight at the speed, as when I am walking it is just fine.
**Also not sure if this is normal but if I let of the camera on the vest the camera and vest arm fly away from my body to where I have to pretty much hold the arm so the camera doesn't pull away with the arm.
