Marshallarts
First off, I should say what I'm trying to stabilize is a locked down camera on a tripod. It is a long duration shot and no matter how many signs you make people always manage to bump it.
I've found stabilizing in AE using it's brilliant trackers is about as effective as kindly asking your camera to shake less. I've found it's trackers to be next to useless in my situations and find it unbelievable it works so well in tutorials I've seen. I do no need a lesson on stabilization, and I've experimented with the perimeters under options as well. After trying dozens of methods using dozens of different search regions I can't stop the trackers from drifting. Even when there are periods of absolutely no movement the trackers seems to jump around.
Because I find the trackers to be so awful I would like to attempt to paint in my own markers. But now I have to learn how to do that. I only need to paint it manually in the frames where the tripod is bumped. In between those frames I would like to apply or paste the markers in the same locations.
I've spent 5 hours trying to learn how to do this. Anyone have advice?
