Hi to all.
I'm a new entry of this forum, but I read your posts from 2007, when I started to work with FCP.
Sorry for my english, I'm writing from Italy, so maybe my language is not correct at 100%.
Just for a simple presentation of me, you can look my works on vimeo (here) .
I have a question about Final Cut Pro X and smoothcam (called now stabilization).
I hope you can help me to fix a problem that I have. I will try to explain better that I can, my situation.
My new final cut pro x project is about a concert. I recorded it with 2 cams.
One camera was stable on a normal main position, I used it only for base of my video.
One camera on my hand, used to take faces, particulars, singers and etc etc.
To simple the edit I just start to record on the two camera, and then I never stop to record.
On my project I have now a storyline (first cam), I putted on top of it the second clip of the second camera.
It all ok. After the synchronization of this two clips, I have edit my project wit a color correction to "merge" the two cams (a little canon legria and a Canon XHA1s). I have cut all the movement of my second camera, and then fixed all my clips on the primary story line, with cross fade. A VERY SIMPLE PROJECT, OK?
Now my project is near to end. But I have one problem.
Some clips of my second cam (the hand came) have to be stabilize.
I actives the stabilization option and FCPX start to analyze the clip.
But now is working from 3 hours!!!
I think that FCPX is now analyzing ALL the man clip, not only the clip of the sequence...
On last version of Final Cut Pro, it does the same, so I used this workaround:
Select the part if clip that I have to stabilize;
export that part;
reimport like a new clip;
insert on my project on the same place of last one.
Apply the smootcham filter.
I have to use the same workaround on FCPX???
export that part;
