Thanks. I bought this one used but I didn't think to check for dust. I suspect it was there all along, but I just noticed it recently when I was pixel peeping a used lens that I bought and DID notice some dust in the front/rear elements. That dust didn't register, but I noticed this in the process. As mentioned it only shows up under certain conditions and one of them is with the speedbooster and FULL FRAME EF lenses. Not my s35 glass.Noticed a few earlier in my life that had me beginning to check brand new cameras straight out of the box.
Closed the lens all the way down at noon, pointed straight at the sky.
Almost always something there, rarely ever perfectly clean.
It bothered me to no end but I learned to let go, it wasn't easy (so I hear you).
Another thing added to my lifelong list of how imperfect human processes are (and I see a future with cameras being assembled in special chambers with only machines in them which have small air intakes near the parts that are handling the camera parts and putting them together).
___
I haven't used them, or any service; I just returned a camera once or twice.
Wow, interesting. I thought for sure you had a warehouse full of gearYup, it's mentally debilitating (the strong OCD).
At this point I don't own a single piece of camera gear besides my new iPhone.
The weight is off my shoulders, hated worrying about everything, I'll rent everything I'll ever need.
[Someone's thinking, 'you guys are nuts', lol.]
Wow, one of us who actually was cured of GAS!well, I used to! in the glory days, they're done
That's your problem right there. It's crap on the sensor. No digital camera should be used beyond f/5.6- f/8 because of this problem. That's the 2nd reason why we have ND filters. I'll bet every one of my removable lens cameras would show spots at f/11 when shooting a sky or other plain background. But shoot wide open and it all disappears.Thanks, Norbro. Yes, the one you circled. It's most visible at f11 up.
Thanks for the helpful advice, Doug. I've swabbed the sensor probably ten times so it's definitely inside the sensor block. I think ND is probably the best solution short of sending it in to Canon and there's no guarantee that $300 later more dust won't settle in there...That's your problem right there. It's crap on the sensor. No digital camera should be used beyond f/5.6- f/8 because of this problem. That's the 2nd reason why we have ND filters. I'll bet every one of my removable lens cameras would show spots at f/11 when shooting a sky or other plain background. But shoot wide open and it all disappears.
Easy enough to fix. Turn the camera off, take the lens off, and shine a flashlight in there. You'll probably see that dust and others. Use a lint-free swab (looks a q-tip but not a q-tip) to blot it off. Don't scrub. And remember, the image is flipped on the sensor, so if the spot is at the top of the screen then you'll see the dust at the bottom of the sensor.
You can easily fix the shot in Resolve by drawing a power window around it, adding some feathering, and then cranking up the blur to make it disappear.
You'd know better than I would since you actually have the camera in your hands, but with that said, I've never encountered any dust on the sensor of my Sony or Panasonic cameras that couldn't be removed the way I described. But then again, I don't worry about it too much because I shoot wide open 99.9% of the time.Thanks for the helpful advice, Doug. I've swabbed the sensor probably ten times so it's definitely inside the sensor block.
Yeah, and that's exactly what I told Canon. I've owned fs5, fs7, a7siii, fx3, and fx6 and not once did dust enter the sensor block. They didn't want to hear it...You'd know better than I would since you actually have the camera in your hands, but with that said, I've never encountered any dust on the sensor of my Sony or Panasonic cameras that couldn't be removed the way I described. But then again, I don't worry about it too much because I shoot wide open 99.9% of the time.
You’re sure it’s not the speedbooster causing the issue? If that’s a common element…As mentioned it only shows up under certain conditions and one of them is with the speedbooster and FULL FRAME EF lenses.
Yeah, I tried it with the standard rf-ef adapter ;(You’re sure it’s not the speedbooster causing the issue? If that’s a common element…
Thanks, Jeff. I spoke to them a few times on the phone and I liked their vibe. They quoted me $285 over the phone. I sent it to Canon and they quoted me over $400 but offered a 20% discount because I argued that the previous owner had had the same service done over a year ago and that the sensor unit should be reasonably sealed and that I never had this issue with Sony. Then they basically lectured me about using the camera under adverse conditions and I told them I’ve had three indoor shoots since I got it. Anyway, good advice from you and others to just let it be and fix it in post or used NDsscorsesefan,
I've used Photo Tech many times for camera repair, they are very good. They used to be located on 13th street in a large space with their techs in the same room and a counter in front. So you could go in and if they were slow they would look at your camera while you were there. A few years ago they moved up to west 30s a few blocks from B&H. I believe they now ship all repairs to a bigger facility in NJ. They used to offer free estimates not sure if they still do. I agree with the others, in your case its a waste of money and an easy fix in post.
Jeff
I have a photo loupe somewhere but I need to dig it out...Do you have a loupe? I bought mine years ago for cleaning my DSLR sensors. Dust drives me nuts as well but most of the time I also shoot pretty wide open so I've (sort of) learned to live with it. Something like this, it does help to see any lurking debris:
https://www.bhphotovideo.com/c/product/1763952-REG/visibledust_19132204_quasar_plus_7x_sensor.html
