Spinning image with M2 adapter
Hi,
What does it mean when you can actually see a spin in your image when using the M2 adapter? Is that just one of the 'cons' of using this adapter or is that particular adapter defective?
My thanks for your time.:dankk2:
Assuming you're not shooting at some unusually high shutter speed, it usually means your GG is spinning too slowly, which usually means your battery is dying. (Some cold conditions can make a battery seem deader than it really is...but assuming you're not out in the subzero temps, the battery probably just needs replacing.)
Duncan
